roleyfoley wrote:
Cool thanks for that, thats what dad said as well when i just spoke to him. Looks like i have a really good excuse to start the rebuild work i was planning on doing
if you want it back on the road, you can do the clutch while it is in the car. If your going to do just this job, check the plunger and arm for wear, get a new clutch kit (diaphram, plate) and of course new bearing. Probably cost you $150 for the kit, $60-80 for a bearing, $100 bux for new arm and plunger (worth replacing if they are worn).
If you have destroyed the bearing, you have damaged the faceplate on the diaphram too.
Youll need a clutch puller, and a 32mm or 1 1/4 socket.
