I went to start my car the other day, turned the key on and waited for it to pull fuel up, next thing bloody great clouds of smoke inside the cab & under the bonnet so i shut my isolator switch straight off ( geez i'm glad i put that in it's easier than trying to disconnect a battery in a hurry ), turns out it melted the dual white wire that runs from the ignition to the fuse box so i replicated the wire and replaced it , checked the rest of the wiring as best as i could and can't see any obvious problems that might of caused this to happen.
Hooked up new wire & watched around the ign switch as i turned the the key to the on position and sure enough it started to heat up the white wire again as well as the 2 brown wires that come off the switch,the heat doesn't appear to be going past the fuse box so i am thinking that my ignition switch has shat itself.The weird thing about it is the bloody car was fine last time i drove it ,put it the shed locked it up no problems. Does this sound feasible?
