It is currently Tue Aug 19, 2025 8:43 pm
 Post subject: Engine Sealant Question
PostPosted: Sat Aug 29, 2009 9:57 pm
Hi,
At the moment my mini is due an oil change and its got one oil leak from somewhere around the timing case that i will fix, but probably after the muster.
Has anyone had any experience with the engine sealant that you pour in with the oil and it clogs the holes?
Does it have any negative effects on the running of the engine?
Joe
Simplify and add lightness
PostPosted: Sat Aug 29, 2009 10:01 pm
would not touch it. Change gasket on timeing case and do it correctly
PostPosted: Sat Aug 29, 2009 10:08 pm
This space for rent
I'm sure it'll seal up holes. Think about all the holes inside the engine you don't want to seal up.
Quick fix stuff like this is always bad news.
PostPosted: Sat Aug 29, 2009 10:53 pm
How could it possibly work? It is a scam in a bottle.
PostPosted: Sun Aug 30, 2009 6:42 am
hmm freinds of mine put this crap in there old suzuki 4x4 one of the old short wheel based ones....it was smoking and leaking oil....something weld it was called....and it work a treat....but i too would be carefull as im not sure what it dose to the internal parts of an engine..he olny use the car a a once a week run around so i dont think its a quick fix a a car u plan of driving everyday...
