It is currently Thu Aug 21, 2025 2:55 pm
 Post subject: Clutch bleeding
PostPosted: Sat Aug 29, 2009 9:12 pm
I need to bleed my clutch hydraulics after replacing the rubber on my slave cylinder. Problem is: I've not done this before, and just spent an hour following my manual's instructions and still have a very spongy pedal that's not doing much.
I ended up getting my rubber tube filled with fluid, couldn't see any air bubbles, but to no avail. This is what I did:
Opened bleed valve, pedal depressed slowly, closed valve when fluid stopped moving, raised pedal. Repeat.
Does it help if the container is higher/lower than the valve? Short tube/long tube? I'm out of ideas :oops:
Thanks
Andrew
PostPosted: Sat Aug 29, 2009 9:18 pm
Tomboss Breweros
Have your assistant pump the pedal 5 times and hold it to the floor, open them close the nipple. Pump the pedal, let it rest a few seconds and see if its better.
It should come good after a few shots.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Aug 29, 2009 9:24 pm
Youv still got air in the system, do what the mad scientist said :D
PostPosted: Sun Aug 30, 2009 7:29 am
Thanks. I'll try it. :)
Andrew
PostPosted: Sun Aug 30, 2009 8:59 am
If your just bleeding the clutch, put a plastic tube onto the bleed nipple on the slave and run it back into the master cylinder resivior into the fluid.... Crack the nipple open and pump it through a few times. Should get rid of any air in the system and you shouldnt get too much fluid every where
Life's a garden.... Dig It!
PostPosted: Sun Aug 30, 2009 9:01 am
the trick with clutch bleeding is to release the bleed nipple & shut it off fast,,, just a quick squirt,,, don`t let it open for long at all
Just depress the peddle, quick release squirt & shut it off
do that a few times & all will be well
(unless you have "Other" problems)
PostPosted: Sun Aug 30, 2009 3:36 pm
if you got long enough arms you wont need an assistant, you can reach through to the engine bay while you have your foot on the pedal.
PostPosted: Sun Aug 30, 2009 4:24 pm
lol - I'm 6' 4" and I don't have a hope of doing that - not without taking the door off the car
a bar propped between the pedal and crossmember works slightly better
PostPosted: Sun Aug 30, 2009 4:44 pm
All fixed. :) Dragged the Minister for Finance out to the shed to pump the pedal for me. It took a while for me to nut it out as 5 pumps wasn't doing much to start with. Plenty more and I saw the arm start moving and could then start getting the air bubbles out.
Thanks! Ausmini is awesome. 8)
Andrew
Users browsing this forum: No registered users and 335 guests
