It is currently Fri Aug 22, 2025 9:07 pm
PostPosted: Sun Aug 30, 2009 8:38 pm
i am just assembling my engine and i think when my block was recoed i never got back a few things that screw into back of the block (1275) see pic i have 4 holes that need to be plugged
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Sun Aug 30, 2009 9:48 pm
The hole below the fuel pump hole doesnt need to be plugged and the hole in the centre of the block can also stay un plugged. The two holes at the RH end of the block are for the water & oil gallary plugs, these two need to be plugged up, the oil plug is steel with a copper washer & the water plug is brass with a copper washer.
Have a Nice Day.
