It is currently Sun Jul 20, 2025 6:41 am
PostPosted: Sun Sep 06, 2009 8:13 pm
Got the passenger hub off and decided to - for some reason to check the wheel cylinders - frozen solid :evil: One had a lot of grit in it the the other has a rusty ridge - one of the pipe connector screws broke off trying to unscrew it - so I gues it's new wheel cylinders - should I go genuine or OEM = $6 per cylinder difference so not a big deal. Would there be a marked difference in quality? (twin leading shoes - 15/16" bore)
David L
PostPosted: Sun Sep 06, 2009 9:01 pm
I would have expected new wheel cylinders in a big thorough rebuild anyway. :lol:
You could always get yours rebuilt with stainless sleeves. But I would go with the best quality replacements.
Don't forget to do all the rubber hoses too.
PostPosted: Sun Sep 06, 2009 9:08 pm
Has new rubber hoses - I remember re furbing the rear cylinders - don't think I did the fonts when I looked at them when I first got the car - it had new back plates, springs and cylinders looked new at the time - I just added new pads , machined the drums. But I guess sitting for 9 years doesn't help.
David L
PostPosted: Sun Sep 06, 2009 9:17 pm
Doc gave some good advice a while back, try packing the outer rubber boots with a little rubber grease when the cylinders are new. It's the corrosion which forms here when the breaks are unused that seizes or or causes leaks with the cylinders when the the brakes pistons try to operate over the exposed surface.
I'm not sure how long the rubber grease will remain in place and continue to protect the exposed surfaces, but its better than a poke in the eye I say and I've been doing this since. In the past my minis have had to sit for long periods while I'm away with work, and it seems to have worked really well.
PostPosted: Sun Sep 06, 2009 9:27 pm
as I'm putting a 998 engine in to Marcia now I'm also going drums on the front also. I have to rebuild from scratch as I gave my old parts away as I didn't think I'd needed them again :roll:
I aquired a pair of 1" wheel clinders so the other side will get the same every thing will be new from thier also. Ill do a how to :lol:
Check the adjusters while your at it David
