What are you planning for the Mini this weekend? https://www.ausmini.com/forums/viewtopic.php?f=2&t=56710 |
Page 1 of 2 |
Author: | Wombat [ Fri Sep 04, 2009 8:06 am ] |
Post subject: | What are you planning for the Mini this weekend? |
I'm on call this weekend so can't leave the house - so the laptop will be down in the garage with the $1.50 silicone keyboard protector and I'm getting stuck into the Mini. The plan:- 1..Thin skin of bog on the hammer dents on both doors 2..Pull the passenger side hub off and change the bearing over to roller 3..lap and reshim the swivle joints 4..pull out the lower arm and tie rod and fit new adjustable parts 5..tackle the removal of the passenger A panel 6..cut a new fuel sender gasket and fit fuel sender to tank 7..install tank 8..bling a lockable fuel cap to sell 9..fit relays to the headlights 10..unpick/measure old seat covers to make patterns for new If I get half that done I'll be happy ![]() |
Author: | drmini in aust [ Fri Sep 04, 2009 8:50 am ] |
Dyno Day tomorrow...... ![]() |
Author: | mattsmadmini [ Fri Sep 04, 2009 8:54 am ] |
when i finish uni today, hopefully get a new exhaust fabbed up, and my sheared bolts off my drive shaft... ![]() then start sanding back and hi priming, and finish installing my hi-lo's ![]() |
Author: | jess [ Fri Sep 04, 2009 9:12 am ] |
Washing Polishing Putting on new trim Attaching CHERRY badge |
Author: | beastymini [ Fri Sep 04, 2009 9:19 am ] |
Finish installing the dash and making up a new hood lining with some vinyl i picked up ![]() |
Author: | BALLISTIC [ Fri Sep 04, 2009 9:32 am ] |
Saturday BALLISTIC...... Fit new steering rack Fit new headlight and high beam relays Fit new top engine steady bushes Fit 2 tyres Adjust rear high lows Service, tune, grease and general inspection Upload new music to ipod Moke...... Remove engine/gearbox, Split engine from gearbox Change diff ratio to 3.44 from 4.1 Fit centre oil pick-up Refit gearbox to engine Refit engine/gearbox into Moke Van....... Tune engine Change needles in twin carbs and tune Sunday..... Fathers day...... Expect the unexpected |
Author: | sgc [ Fri Sep 04, 2009 9:43 am ] |
Just a grease'n'oil change and general service before The Job, I got the mechanical stuff out of the way during the week ![]() |
Author: | IwannaMini [ Fri Sep 04, 2009 10:09 am ] |
JESUS... I plan on enjoying the bejesus out of my Mini.... trip to dyno. Give her some time to play with other Mini boys and girls, then off to the Hunter Valley for some premium petrol tasting from a number of different petrol stations, then home again for a wash and polish... ![]() |
Author: | kuzzy [ Fri Sep 04, 2009 10:30 am ] |
Hill Climb car being built: 1. Mini Automotive for an extensive parts list 2. Fit steering column 3. Trial fit flares If I get to No 2 on the list I'll be happy! ![]() Nb Racer: 4. Swap tyres around 5. Give it a good clean ready for next weekends show |
Author: | qa50 [ Fri Sep 04, 2009 10:32 am ] |
I'm going to take the 850 to a local car show on sunday if the weather is nice. |
Author: | mini-dunger [ Fri Sep 04, 2009 10:34 am ] |
Setting up the fully adjustable front suspension.... in the shed |
Author: | Drexxle [ Fri Sep 04, 2009 11:11 am ] |
Driving to Marree, the gateway to the real outback. And then the hard slog of the Oodnadatta WOOT! |
Author: | Mini Mad [ Fri Sep 04, 2009 11:37 am ] |
mattsmadmini wrote: when i finish uni today, hopefully get a new exhaust fabbed up, and my sheared bolts off my drive shaft...
![]() then start sanding back and hi priming, and finish installing my hi-lo's ![]() get the exhaust fixed, fixed the driveshafts and off to the dyno day!! ![]() |
Author: | simon k [ Fri Sep 04, 2009 11:46 am ] |
I might change my alternator, and might go and pump up a guys suspension.... if I get around to it... |
Author: | Maxi23 [ Fri Sep 04, 2009 12:15 pm ] |
After now having it completely fixed...omfg how awesomly awesome it is to drive now!....I was hoping to go for a spin on the old pac or something. But no...I am moving house and will be driving a bloody ute all weekend. |
