mini-dunger wrote:
Would caster be affected by not having any weight on the suspension components?
Yes, because the point at which the caster arm attaches to the lower arm swings through an arc of radius equal to the length of the caster arm, the caster angle will differ slightly between full compression and full droop.
What I do when I'm measuring mine is, with the car on axle stands lift the front suspension to normal compression with the trolley jack and then measure the caster in that position. But I really only do that to get the settings there or thereabouts; most of the adjustment to get it tracking straight is done as a result of road testing with the car on the ground.
In your case, I'd just set your new arms to the same length as the old and tweak it from there.
[edit] Oh, one thing to consider when setting caster -- when you tighten the nuts on the bush end of the arm, you're compressing the bushes and increasing the caster angle as a result. On the laser rig which measured the changes dynamically this amounted to over half a degree change. It's therefore important that you torque the nuts on both arms equally so you change the caster on each side the same amount, otherwise all your measurement is for nothing
