It is currently Sun Jul 20, 2025 9:03 am
PostPosted: Mon Sep 07, 2009 5:30 pm
Tomboss Breweros
I'm about to put a rod change box together, ony i can't find my manuals (still in boxes somewhere :oops: )
What i'm after is the top picture of the box so i put the selectors back on the cluster the right way.
Also what is the diff side housing shim process, really i need the formula for the clearance minus gasket thickness to set the preload.
Thanks,
Tom
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Sep 07, 2009 7:24 pm
Sorry I don't have a pic of the selectors, but they are not hard to figure out.
Later style diff `angular contact' bearings (with `thrust' marked on one side) have .005" preload when new. The thrust marked faces go to outside.
Early style `deep groove' diff bearings only got .001-.002" preload.
I assemble the RH side cover and tighten the 5 bolts.
Then, I sit the box on its RH side. This stops the shims behind the LH cover falling about and getting trapped out of position before the cover is tightened..
PostPosted: Mon Sep 07, 2009 10:00 pm
the current ones aren't marked with 'thrust' sides are they?
the gaskets I put in my gearbox a few weeks ago were .015" thick - so twice that is pretty thick. I put a shim between the inner race and the crown wheel to move the bearing out so it didn't need 60 odd thou of shims
shims = gasket - .002"
PostPosted: Mon Sep 07, 2009 10:09 pm
Yeah the side gaskets now are bloody thick.
I put a .010" shim on the RH cover to start with.
I have also built a few boxes with NO side cover gaskets, just Loctite 515 Master Gasket sealant. No leaks... :wink:
re the bearings, the angular contact outer rings have a thick side, this goes outwards. Used to be marked `thrust' but maybe the caring folk who make these now don't bother. :lol:
PostPosted: Mon Sep 07, 2009 10:16 pm
oh balls.... I hope that's the side with the writing on it
PostPosted: Mon Sep 07, 2009 10:21 pm
Yep it is, you can sleep now Simon. :P
PostPosted: Mon Sep 07, 2009 10:25 pm
thanks Kev - dodged another bullet :roll:
PostPosted: Tue Sep 08, 2009 7:25 am
Tomboss Breweros
Thanks Simon,
Thats the equasion i was after :D
kimini wrote:
Jimmyinamini wrote:
