It is currently Sun Jul 20, 2025 8:31 am
 Post subject: a+ drop gears
PostPosted: Tue Sep 08, 2009 7:19 pm
Can i machine down a+drop gears to fit into an a series case
cheers allan
PostPosted: Tue Sep 08, 2009 7:44 pm
i found out for myself and the answer is only if you get it case hardened again.
cheers and thank you for your help allan
PostPosted: Tue Sep 08, 2009 7:56 pm
Glad to help. 8)
PostPosted: Tue Sep 08, 2009 9:46 pm
Rather than machine the idler gear, have the idler gear bearing holes in the case/transfer housing bored out and fit the larger bearings.
Have a Nice Day.
PostPosted: Tue Sep 08, 2009 11:51 pm
ah,,, er,,, um,,, why not just fit the right gear set instead???
PostPosted: Wed Sep 09, 2009 4:25 pm
i had a spare set here and thought i might be able to do it but im not
