a+ drop gears https://www.ausmini.com/forums/viewtopic.php?f=2&t=56854 |
Author: | lil-ute [ Tue Sep 08, 2009 7:19 pm ] |
Post subject: | a+ drop gears |
Can i machine down a+drop gears to fit into an a series case cheers allan |
Author: | lil-ute [ Tue Sep 08, 2009 7:44 pm ] |
i found out for myself and the answer is only if you get it case hardened again. cheers and thank you for your help allan |
Author: | Morris 1100 [ Tue Sep 08, 2009 7:56 pm ] |
Glad to help. ![]() |
Author: | 850man [ Tue Sep 08, 2009 9:46 pm ] |
Rather than machine the idler gear, have the idler gear bearing holes in the case/transfer housing bored out and fit the larger bearings. |
Author: | TheMiniMan [ Tue Sep 08, 2009 11:51 pm ] |
ah,,, er,,, um,,, why not just fit the right gear set instead??? |
Author: | lil-ute [ Wed Sep 09, 2009 4:25 pm ] |
i had a spare set here and thought i might be able to do it but im not |
