When is it time to replace fuel pump.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=56938
Author:  Mynute [ Fri Sep 11, 2009 6:34 pm ]
Post subject:  When is it time to replace fuel pump.
My facet fuel pump is giving me some greef only started yesterday.
I had to tap it for it to start pumping :note it does not do it all the time. There is voltage to the pump.
Is there anything I could check to fix the problem or should I just replace it?
Cheers. :?
Author:  grey 64 [ Fri Sep 11, 2009 6:53 pm ]
Those symtoms were the reason i replaced mine. The only other thing left for it do to is fail completely. You dont want that.
Author:  Mynute [ Fri Sep 11, 2009 7:15 pm ]
Thats what i'm worried about should just replace for piece of mind.
Author:  gafmo [ Fri Sep 11, 2009 8:12 pm ]
clean and check all connections.
Otherwise yes if I had the $$ I would replace the pump and keep the iffy one for a spare as we do with starters, alternators etc :lol:
Author:  Mynute [ Fri Sep 11, 2009 8:16 pm ]
Thanks have checked all conections they look fine to me think she is on the way out.
Author:  michaelb [ Mon Sep 14, 2009 6:18 pm ]
When it stops working... :roll:
I just found out when the Mini Van refused to start for my daughter when she came back to the car park from the Supermarket.
NRMA membership is great insurance when you own a mini :D
Problem diagnosed and car towed home.
Just need the time to replace the pump now :(
Author:  Mynute [ Mon Sep 14, 2009 7:29 pm ]
Well, replaced the pump tonight this will be a piece of mind. :lol:
