It is currently Fri Aug 15, 2025 3:39 am
 Post subject: Air filter 1.75 hs6 su
PostPosted: Sat Sep 12, 2009 5:20 pm
Suggestions on air filter for a single 1.75 hs6 su on a minisport manifold , the engine is a 1293. I am thinking of a K&N cone with a sub stack ?
PostPosted: Sat Sep 12, 2009 8:11 pm
I make stubstacks for HS2 and HS4, but for HS6 I don't bother.
Just do what GR does- bung the HS6 in a lathe and machine a decent radius into the inlet port.
This way no need for a stubstack, and less restriction around the insides of the filter.
If you go for a drive to GR's he could maybe do it while you wait. :wink:
Users browsing this forum: Bing [Bot] and 218 guests
