When lowering with hilo's do you need to..... https://www.ausmini.com/forums/viewtopic.php?f=2&t=56979 |
Author: | Blunder [ Sun Sep 13, 2009 1:01 pm ] |
Post subject: | When lowering with hilo's do you need to..... |
Do I need to remove the bump stops completely or cut them down?! I noticed that the top arm is resting on the bump stop effectively stopping the car sitting where I want it to! Thanks people! |
Author: | NAV [ Sun Sep 13, 2009 5:34 pm ] |
Post subject: | Re: When lowering with hilo's do you need to..... |
gareth-in-adelaide wrote: Do I need to remove the bump stops completely or cut them down?! I noticed that the top arm is resting on the bump stop effectively stopping the car sitting where I want it to!
Thanks people! If it's sitting on a bump stop it means you've got 3/4 of bugger all suspension travel left. Why you would want a mini that low i don't know but removing the bump stops will never end up doing any good as when you bottom out it won't be a soft rubber but metal to metal, and the suspension wont work if it can't compress. In short, don't do it. |
Author: | Blunder [ Mon Sep 14, 2009 9:12 am ] |
The thing is it doesn't seem that low!!! There is still a gap just smaller than my fist size from tyre to arch! Which looks alot! |
Author: | Davo111 [ Mon Sep 14, 2009 9:17 am ] |
something don't sound right, the bump stops arn't from a Kenworth by any chance are they, measuse the thickness and let someone on here know what that is and they should be able to guide you a bit further.. |
Author: | awdmoke [ Mon Sep 14, 2009 9:44 am ] |
1 to 2mm clear of the bumpstops is where you will achieve the best handling |
Author: | Tombo [ Mon Sep 14, 2009 9:55 am ] |
Mine has about 5mm clearance to the bump stops which are in good condition. Heres a pic of how it sits, not the best angle, the front guards have about 35mm gap. Do you have small hands ![]() ![]() |
Author: | NAV [ Mon Sep 14, 2009 9:58 am ] |
Sorry, I assumed you were going for ridiculously low. The STD bump stops are only about 10mm thick. Check the minisport website to see if the bump stops look the same as what you have. |
Author: | Tombo [ Mon Sep 14, 2009 10:03 am ] |
NAV wrote: Sorry, I assumed you were going for ridiculously low.
The STD bump stops are only about 10mm thick. Check the minisport website to see if the bump stops look the same as what you have. ![]() |
Author: | simon k [ Mon Sep 14, 2009 10:14 am ] |
NAV wrote: The STD bump stops are only about 10mm thick.
you might be thinking about the rebound pads that go under the top arm... Gareth, leave it as is and go for a drive up and down the street and see where it settles to |
Author: | NAV [ Mon Sep 14, 2009 1:00 pm ] |
simon k wrote: NAV wrote: The STD bump stops are only about 10mm thick. you might be thinking about the rebound pads that go under the top arm... ![]() |
Author: | Blunder [ Mon Sep 14, 2009 1:06 pm ] |
I'm talking these things!! Lol http://minisport.com.au/prod479.htm |
Author: | awdmoke [ Mon Sep 14, 2009 1:31 pm ] |
Should not need to remove or alter them |
