Rover master cylinder / booster in a Moke
https://www.ausmini.com/forums/viewtopic.php?f=2&t=57252
Author:  poeee [ Mon Sep 21, 2009 6:57 pm ]
Post subject:  Rover master cylinder / booster in a Moke
I was just wondering if anyone has ever fitted a Rover master cylinder / booster setup in a Moke?
I have everything here and would like to know what others have done before I pull the angle grinder out.
The problem is with the firewall mount for the master cylinder / booster bracket. It extends too far back for the Moke firewall. This part that extends back has a spring on it to return the brake pedal, and then a hole to put a bolt through in to the firewall. I was thinking of lopping this bit off and using the spring that is normally on a Mini brake pedal, as the Rover one does not have a spring on the pedal pivot.
Pic to come...
Edit/ Pic is here.
Author:  poeee [ Mon Sep 21, 2009 8:24 pm ]
Pic added.
Author:  850man [ Mon Sep 21, 2009 8:34 pm ]
I have done it, ill try and find the pic. Works well.
Author:  850man [ Mon Sep 21, 2009 9:00 pm ]
I built the engine for a good friends of mines Moke, 1380, 5 speed, Metro vented discs etc. We used the Rover booster as they work so well. Cant remember exactly what we did to make it fit, but is wasnt hard.
Author:  poeee [ Mon Sep 21, 2009 9:06 pm ]
Yer looks like you guys chopped the end off. Cheers!
Author:  Beanie [ Tue Sep 29, 2009 6:11 pm ]
curl that end underneath the booster if possible you still need that extra bolt it does heaps to stop the booster flexing around
Beanie
