brakes
https://www.ausmini.com/forums/viewtopic.php?f=2&t=57390
Author:  weeman90 [ Sat Sep 26, 2009 5:48 pm ]
Post subject:  brakes
hi i have replaced my front wheel cylinders , bled all , adjusted and i still dont have a pedal till the last little bit there is also a couple of drops of brake fluid below the brake pedal so am i right in thinking the problem could be with the master cylinder ?? is there anything else i should try before i replace the the master cylinder??
cheers jarrad
Author:  kiwiinwgtn [ Sat Sep 26, 2009 6:03 pm ]
If its leaking inside the car then its a master cylinder issue and you will never get pressure until its repaired
Kiwiinwgtn
Author:  weeman90 [ Sun Sep 27, 2009 6:37 pm ]
ok i will replace it and then see how i go .
Author:  4myego [ Sun Sep 27, 2009 8:51 pm ]
http://www.ausmini.com/forums/viewtopic ... ht=#665620
Try first
Steve
