Hi all,
I recently had my alternator die on me. I then bought a new lucas-style from convertable mini man (Tony), and with my lack of experience promptly blew it up by wiring it in wrong.
Anyway, I managed to fix the old one, but I'm getting quite a high voltage from it - 14.55V to be exact across the battery terminals at and above 2800 rpm. Is this too much? I was thinking the regulator has blown, since the method used to fix this alternator was to pull the whole thing apart, test everything and put it back together. As far as I know, you can't really test an internal regulator without specialist equpment. The alternator's a Lucas 16acr
On a side note, does anyone know how to get those chinese lucas-style alternators apart? It seems that either the back is bearing pressed on, or I need to take off the pulley and fan, and it's not easy. I've already bent the allen key.
Thanks in advance.
