It is currently Fri Aug 01, 2025 1:17 am
 Post subject: Roof replacement
PostPosted: Tue Sep 29, 2009 6:40 pm
Hi, just looking for some photos of roof replacements (??) I need to replace a roof as it is very rusty, and I would love to see "how too" do it.
Nat
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
 Post subject: Roof Replacement
PostPosted: Tue Sep 29, 2009 7:44 pm
I have seen them do a modern car . All they use is Urathane and Glue it on. I think it will be a good Idea on a Mini as it will not burn any panels and cause any rust again.
"Let us remove your "SHORTS"
PostPosted: Tue Sep 29, 2009 7:49 pm
From what I remember of the photos of this particular car the whole roof will need replacing through the pillars. Mick should know all about this. Ask him to see if he has any pics of it.
Mini roofs were resistance welded in the factory with a special type of resistance welding machine that did overlapping spot welds.
The common way to change a roof at home is cut carefully through all the pillars and transplant one from another car.... known as a cut and shut.
PostPosted: Tue Sep 29, 2009 10:44 pm
When they fit the carbon roofs in the uk they cut all but about 3 inches of the roof out. Then resin/sikaflex/sticky stuff the carbon roof overlapping those parts.
Simplify and add lightness
PostPosted: Wed Sep 30, 2009 12:30 am
[quote="drmini in aust"]Mini roofs were resistance welded in the factory with a special type of resistance welding machine that did overlapping spot welds.
The common way to change a roof at home is cut carefully through all the pillars and transplant one from another car.... known as a cut and shut.[/quote]
I'm with the doc here. Pre 74 cars are spot welded, so you can drill out the spot welds and remove the bad roof and bring in a newby. You can drill the laping flange (the bit where its welded on) in the same places as the old roof and the braze it on at the holes, just remember to clean off the brazing with deoxidine and then metho and then thinners to make sure you have removed all traces of the flux, otherwise you might get problems with the paint not sticking and then rusting again. But it will look 99% original. Other thing to remember, while the capilary action of the brazing does help with sealing, don't forget to seem seal it and don't accidently block up the gutter in the process, otherwise you'll need another roof! :lol:
Don't know if that applies to your mini though... Is it an SS? Did it have a spandex roof? Mine didn't have one when I bought it so I didn't have any rust to worry about. If its an SS I'd do what the doc is suggesting because the rooves weren't spot welded at that point. They were resistance welded.
PS, they glue alot of panels onto modern cars from the mid 1990's onward (there is the odd earlier one) pretty cool hey :D ? The thing is that they are designed to be glued together and they work well that what way. Minis are designed to be weld together so it might be a problem...
Just a thought. Thats all.
PostPosted: Wed Sep 30, 2009 9:22 am
Thanks, yes it is the SS and the donar shell is a 73 (I think) although the donar shell is in much better condition than the SS and hubby and I are not sure we can chop it apart!! We may have to buy a 2nd donar shell. Is this a job that relative beginners can undertake? Hubby is quite a handy welder, however he is worried about the body of the car flexing and bending whilst the roof is removed. Not sure what you meant by spandex roof?? We have not pulled the SS apart yet (the roof lining is still in the car).
1976 Mini SS
1976 Mini SS Shell
PostPosted: Wed Sep 30, 2009 9:24 am
Thanks Dr, you make it sound so simple :lol: She says as she is madly chewing her nails....
1976 Mini SS
1976 Mini SS Shell
PostPosted: Wed Sep 30, 2009 10:29 am
Howdy again,
your huby has a good point there about body flex. The roof plays a big roll in holding the body square. But you will find that it won't felx enough to cause problems. Its ok if it does flex around a little bit, you will find as soon as you drop the new roof on and clamp it up, it will hold it square again. When they assembled these in the factory, they only had the floor pan clamped down and it was built up from there. If memory serves they didn't need to use any sought of jigging to hold the body square by the time they reached the roof. If you like you probably can dig up a video on doco from the factory when they assembled them and see for yourself.
PostPosted: Wed Sep 30, 2009 12:49 pm
Phat Kat wrote:
Howdy again,
That would be great to see, if it is not too much of a hassel.
1976 Mini SS
1976 Mini SS Shell
PostPosted: Wed Sep 30, 2009 1:09 pm
I don't actually have that video anymore, I lent it to some punk kid from SA and never saw it again. Don't know where abouts you live, but there is a shop In parramatta, sydney, nsw called Wheels Book Store. THe owners name is John. He has an amazing varity of books, DVD's and un-obatinium. He does post.
Ph 02 9893 7033
333 Church street Parramatta NSW 2150.
The dvd is called "The Best of the Original Mini", its a great watch. plenty of early footage.
PostPosted: Wed Sep 30, 2009 1:57 pm
Ph 02 9893 7033
Thanks we may give him a call :D
1976 Mini SS
1976 Mini SS Shell
PostPosted: Wed Sep 30, 2009 2:13 pm
The video of the last Mini body being assembled is on the Sommerford Mini Catalogue CD. As PK says they only use a jig to hold the shell square to put the roof on - so it is the roof that is the key to the squareness of the whole body :?
David L
PostPosted: Wed Sep 30, 2009 3:48 pm
Isnt that footage on youtube somewhere...?
*EDIT* "Building a Baby Austin" on youtube shows the body being assembled...about halfway through Part 1
PostPosted: Wed Sep 30, 2009 4:09 pm
I'm Bert , where's Ernie
i've got a youtube video of the production line, can see a shell being put together, will dig it up if you like?
*edit - damn, jason beat me to it :lol: *
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
