Mick wrote:
I think you've got a plain old fashioned dead short. Check your wiring in your plug (with a multimeter set to ohms) and also confirm your polarity. The point is supposed to be +ve, the outside is meant to be ground.
If it was a head unit you'd be forking over for a new one by now
But also, is it 12vDC or 12vAC supply? I know you reckon its 12vDC, but is this off the back of the power supply or an assumption?
Back of the adapter says 12 volt 1 amp. It is an AC/DC adapter so I guess its 12 volts. Centre of the plug is positive according to the diagram.
I can give you the in depth technical answers to your problem, but try this simpler one first:
Resistor won't do what you want it to do. Forget it.
Fuses blew because of excess current - you have a short.
Plug melted most likely because this is where you problem is / was.
An adapter lead is easy to make up, but you will require soldering skills to do it properly. Take care with the polarity, there should be a little diagram on the speaker next to the D.C socket showing this.
All it takes is a couple of wire strands or a poorly / incorrectly assembled plug and it will do what you described.
Hope this helps Very Happy
What is the technical answer? Why wont an inline resister do what I want? Are you suggesting the plug is shorted? It didn't seem to mind when I plug it in with nothing plugged into the other end. The plug is stuffed now but wasn't before I don't think.
Is it possible that these speakers will just draw as much current as they can cause they expect the adapter to limit the current? I have another plug with an inline fuse and another plug and I'll solder it up but I expect similar results. At least this time the 1amp fuse will blow first I suppose...
