It is currently Thu Jul 24, 2025 5:50 am
PostPosted: Mon Sep 28, 2009 11:11 am
Milatsmadmini
Do we have one? my cars indicators have gone on the fritz, has spent the past few days at malure's to no avail.... if it was anything else i wouldnt really bother, but indicators.... kinda a necessity... unless you live near bondi junction and have a moke... then its all in brawl! :lol:
PostPosted: Mon Sep 28, 2009 11:14 am
This space for rent
It's a bad earth.
PostPosted: Mon Sep 28, 2009 11:29 am
Milatsmadmini
its not.
PostPosted: Mon Sep 28, 2009 1:10 pm
sgc wrote:
It's a bad earth.
Well there's no need to be so negative about the whole planet, there are some nice people doing good things every single day :wink:
PostPosted: Mon Sep 28, 2009 2:15 pm
There's an old bloke who trades as Glebe Auto Electrical. He knows his stuff. I forget his name, but I'd definitely take it to him. 8)
2 Mansfield Street
Rozelle
(02) 9810 4455
PostPosted: Mon Sep 28, 2009 2:20 pm
weevel wrote:
sgc wrote:
It's a bad earth.
Are you positive he's being negative?
David L
PostPosted: Mon Sep 28, 2009 2:51 pm
Milatsmadmini
thanks Boyracer :wink:
PostPosted: Mon Sep 28, 2009 4:41 pm
Delta Auto Electrics and Air Conditioning
"Addy"
28 Cottam Avenue Bankstown NSW 2200
Ph: 9796 1101 or 9707 2965
PostPosted: Mon Sep 28, 2009 5:14 pm
Check the fusebox.
Check the flasher can.
Check the switch.
PostPosted: Mon Sep 28, 2009 5:38 pm
Wow, that didn't last long. :lol:
PostPosted: Mon Sep 28, 2009 5:44 pm
I had all sorts of unexplainable things with my MG.
Although they looked newish I changed all the little black plugs
and every thing worked.
The guy from Vintage Harness? (I think) said the older ones although
new were brittle and he was right because most of the joiners were cracked.
PostPosted: Mon Sep 28, 2009 6:10 pm
Milatsmadmini
greig and i spent a good hour going over those 3 things Mick, just dodgey wiring from PO, the indicator line was spliced into the fuel gauge, same fuse i know, but something is still causing it to short out.... dont think Grieg has anymore fuses :lol:
also discovered that sometime in its past life, someone had put half of a new harness in there, but left the old one lol....
i hate wires, and with that ill check out those sparkies :)
PostPosted: Mon Sep 28, 2009 9:27 pm
Delta
Addy and his boys are good
Steve
 Post subject: Auto Electrical problems
PostPosted: Tue Sep 29, 2009 6:36 am
Most times Auto Electrical problems are always caused by bad unporfessional workmanship. Minis are very simple electrically but when people have no idea what they are looking for or doing, they unknowingly introduce other problems to the existing problem which will make problems even harder to find.
We Charge
$80.00 per hour.
$100.00 if you watch.
$120 if you help
and
$160 if you have already attempted to fix it yourself.
Pricing is also subject to change according to customer’s attitude
( Let us remove your shorts)
"Let us remove your "SHORTS"
PostPosted: Tue Sep 29, 2009 11:48 am
get a boyfriend and tell him it's not working so he can fix it/ get it fied for you :mrgreen:
