help - track width?? further help required : ) https://www.ausmini.com/forums/viewtopic.php?f=2&t=57539 |
Author: | monda [ Thu Oct 01, 2009 8:27 pm ] |
Post subject: | help - track width?? further help required : ) |
Hi All I have been researching on the site and other mini sites\forums, web pages etc for the track width front and back, I have found numerous different measurements - 1203, 1213, 1219, 1232, 1274, 1341 (all mm's) Can someone please confirm if any of these are correct, if not what is the correct measurement, for a few different models if not all models, obviously the cooper s will be wider due to spacer drums etc Thanks |
Author: | Morris 1100 [ Thu Oct 01, 2009 9:07 pm ] |
According to various Australian BMC/Leyland hanbooks. Mini 850, Deluxe & Clubman. Front = 1205mm. Rear = 1164mm. Cooper S & Clubman GT. Front 1231mm. Rear = 1210mm. |
Author: | Mynute [ Thu Oct 01, 2009 10:16 pm ] |
Monda In SA the width for a cooper s front not to exceed 1276 mm back 1236mm Hope this helps. |
Author: | monda [ Fri Oct 02, 2009 6:39 pm ] |
Thanks guys, thats a start |
Author: | monda [ Sun Feb 14, 2010 10:38 am ] |
Hey All, sorry to bring this one back but after further clarification Mynute or anyone else- I know your talking about SA regs but do you mean front 1276 mm back 1236mm is standard cooper s? so you can go to 1301mm for front? My manual does not have the front/rear track width for a cooper s or any other later minis! I am after a manual or pages of a maual showing the track width, basically require proof for an engineer. Even sportspack mini track width would be great. any help appreciated cheers |
Author: | 1071 [ Sun Feb 14, 2010 1:38 pm ] |
Leyland "Black" manual Pg 19 Front: 850/998/997 Cooper - 3' 11 7/16" 1.20m Mini 1100 saloons/vans?Clubman 3' 113/4" 1.21m CooperS 4' 1 1/4" 1.25m Rear 850/998/997 Cooper - 3'9 7/8" 1.64(sic)m Mini 1100 saloons/vans?Clubman 3"10 7/8" 1.82(sic)m CooperS 3'11 21/32" 1.19m I have typed these numbers as printed.... I suggest Leyland were using a Lucas calculator to do the metric conversions. I would maybe trust the Imperial measures and rework the metrics ![]() Cheers, Ian |
Author: | monda [ Mon Feb 15, 2010 4:45 pm ] |
cheers 1071, Leyland were pretty close unfortunately anyone know what a sportspack minis track width is? |
Author: | blue_deluxe [ Mon Feb 15, 2010 10:19 pm ] |
Does anyone else know off hand the track of an ERA turbo mini? Im planning on using that as justification to an engineer for my starlet conversion. As theyve got 4 pot vented discs, 13 inch wheels and a turbod engine from the start. |
Author: | monda [ Wed Feb 17, 2010 6:04 pm ] |
I would be interested in the ERA track too, anyone : ) |
Author: | jbeenz [ Wed Feb 17, 2010 7:24 pm ] |
blue_deluxe wrote: Does anyone else know off hand the track of an ERA turbo mini?
Im planning on using that as justification to an engineer for my starlet conversion. As theyve got 4 pot vented discs, 13 inch wheels and a turbod engine from the start. The era has 13*6 wheels, and spacer drums on the rear, so would not be as wide as a sportpack due to the sp having spacers on the rear. There is a very good website run by some nice people dedicated to the ERA. |
Author: | Mynute [ Thu Feb 18, 2010 6:18 pm ] |
Post subject: | specs |
[quote="monda"]Hey All, sorry to bring this one back but after further clarification Mynute or anyone else- I know your talking about SA regs but do you mean front 1276 mm back 1236mm is standard cooper s? so you can go to 1301mm for front? My manual does not have the front/rear track width for a cooper s or any other later minis! I am after a manual or pages of a maual showing the track width, basically require proof for an engineer. Even sportspack mini track width would be great. any help appreciated cheers[/quote] Monda The specs I gave was for the cooper s with disc brakes that was the largest distance I could go to get passed. Front 1276 mm and the back 1236 this is what the inspector said. 1301mm is to big for SA |
