[quote="adzzza"]I don't know half as much about welding as most on here, but you can forget Ark welding.
At a minimum I have been advised to look at MIG. And as for the cheap jobs, you get what you pay for. A good welder can cost thousands, so you can only wonder how bad a $400 job off ebay will perform!
Good luck.[/quote]
What he said. I have gotten away with an ark welder in a totlal pinch, but I am an experienced welder and I found it a challenge, its to hot... who knows you might be a natural and proove me totally wrong
.... You know what actually, often you find cheap MIG welders at cash conveters and those sought of places. Again, I don't use MIG personally, I prefer Oxy for body work, but there can be a bit of a nack to getting the hang of Oxy and it can be hard to teach yourself to do it PROPERLY. MIG is a bit more forgiving.
Woop you snuck up on me there Ron. Your totally right, a number 6 or 8 tip for oxy and panel shops usually use MIG because its quicker for them to weld in grind it and bog it. I do file finishes as much as possible so I hate MIG with a vengence, the weld is always harder than the parent material which means that its easy to file off more of the parent material than the weld, the other thing is that it is hard to do any forming after you've MIGed something, oxy is nicer because a good fussion weld (like the one you described) is like having no weld at all so it behaves like one consistant material when you beat it.
