It is currently Fri Jul 18, 2025 10:40 pm
PostPosted: Tue Oct 06, 2009 11:56 am
Hello All, Can anyone help with fitting rear seat belts? Our shell is stripped and we are in the process of cleaning up all the interior shell floor etc, just after any tips etc about rear seat belts. Cheers TSB(NSW)
PostPosted: Tue Oct 06, 2009 12:01 pm
This space for rent
A couple of things to consider:
* If the car didn't have them standard, you'll need to reinforce the parcel shelf and then get it engineered.
* If holes have been cut in the parcel shelf for speakers, forget installing seat belts as the mounts will not be strong enough. In this condition, an engineer will not pass them and it shouldn't get through roadworthy inspection either (but may anyway).
