another clutch question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=57646
Author:  Leighton [ Mon Oct 05, 2009 7:37 pm ]
Post subject:  another clutch question
ive been trying to bleed my clutch today.
i have attatched the tube to the bleed nipple on the slave, then immersed the tube into the clutch MC, i get my assistant to pump the pedal, hold, close the nipple, release pedal then repeat.
but im still left with a bubble that sits at the highest point of the tube, because air rises. this bubble moves around the tube when im bleeding, put never goes into the MC.
what am i doing wrong and what can i do?
thankyou for all your help,
Leighton
Author:  jimmyinamini [ Mon Oct 05, 2009 7:42 pm ]
valve closed pump pedel hold pedel open valve close valve relese pedel and repete,thats all i know
Author:  Leighton [ Mon Oct 05, 2009 7:47 pm ]
just tried that, and it does the same thing :x
thankyou though
Author:  drmini in aust [ Mon Oct 05, 2009 7:52 pm ]
Don't pump it, that can aerate the fluid.
Push pedal down and hold, open bleed nipple until flow stops, close nipple , let pedal up.
Works for me... :wink:
Author:  Leighton [ Mon Oct 05, 2009 7:57 pm ]
ok ill give it a go.
Author:  sports850 [ Mon Oct 05, 2009 8:04 pm ]
Am I reading it correctly that you only have open tubing sitting into a container of brake fluid and not a one man brake bleeding valve ? If so just crack the bleed nipple open a touch (not fully open) so the fluid squirts out under pressure but air is less likely to stay in .
Author:  Leighton [ Mon Oct 05, 2009 8:09 pm ]
yes your correct its just a tube from the salve cylinder into the MC, ill try your way too.
Author:  gafmo [ Mon Oct 05, 2009 8:15 pm ]
Post subject:  Re: another clutch question
So what you are doing is any crud that is in the system is being put back into the Master Cylinder and once the air is being pushed out you are then air rating the fluid also.
Get a jam jar and make a hole in to the lid and put the hose in that to the bleeder. Don't reuse Brake fluid buy some new fluid please
Author:  Leighton [ Mon Oct 05, 2009 8:18 pm ]
its all been stripped and drained there is no crap in the system, i see what your saying about air rating the fluid but wouldn't the air rise to the top anyway?
Author:  drmini in aust [ Mon Oct 05, 2009 8:25 pm ]
Yes, eventually. Takes 24 hours they say. :lol:
My bro' once spent 1/2 a day bleeding the brakes on his Imp. No good. Same prob you have.
He was tipping the drained fluid straight back into the MC. :shock:
He did as I suggested, and all good.
Author:  Leighton [ Mon Oct 05, 2009 8:27 pm ]
hmm i guess ill try it gafmos way.
Author:  MG Rocket [ Mon Oct 05, 2009 8:36 pm ]
My father was a motor mechanic and whenever he had trouble with bleeding
brakes...he would let the car sit overnight and next morning the problem
would be fixed!
Basically verifying what the Doc said.
Author:  gafmo [ Mon Oct 05, 2009 8:50 pm ]
do put some brake fluid in the bottom of the Jar and keep the end of the hose below the level of the fluid and keep an eye on the level in the Master
Author:  Leighton [ Mon Oct 05, 2009 8:58 pm ]
yer thanks gaf i think ill try that in the morning
