It is currently Sat Jul 19, 2025 6:16 am
PostPosted: Mon Oct 05, 2009 9:23 pm
Hi people.
As the topic suggests, I am looking at going with a pedal mounted microswitch for the brake lights in my white car.
I am wanting to know how people elimiate the brake pressure switch.
I am at the point with the project where I will need to finalise this (engine in for the last time - after installing the LSD).
On the same topic, I am after the y-piece that sits above the right hand brake hose, and the "bolt" that houses the (normally) pressure switch.
Thanks in advance!
8)
PostPosted: Mon Oct 05, 2009 9:28 pm
Tomboss Breweros
Power brakes should have a blanking plug that fits in place of the switch, then it's just to wire it up.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Oct 05, 2009 9:35 pm
id assume most people just leave it on there.. it doesnt affect anything when its not connected. thats what i did with mine
Potato
PostPosted: Mon Oct 05, 2009 10:38 pm
Let me get the link to this from before, I will go and find it.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Mon Oct 05, 2009 10:43 pm
Ah, here it is.
http://www.ausmini.com/forums/viewtopic ... sc&start=0
I just left the pressure switch where it is (it was the third one in a year) and ran the same two wires back to the new mechanical switch that I got from an auto elcetrician. Works well. Hardest part was setting it in the right place to make it work as soon as you put the brakes on.
Member: VMCI #2474
PostPosted: Tue Oct 06, 2009 6:58 am
Mods rock!
HA, Its a Mini !!! (famous last words) or are you selling it !! :lol: :lol:
PostPosted: Tue Oct 06, 2009 11:22 am
So true. 'final stage" = year and a half. Totally jinxed yourself there willy
and i did the exact same as Flut with my switch. left it in and rewired the lights because they only came on when i was locking the wheels
1962 850,Frog
