what fan pulley do I use?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=57728
Author:  junior [ Thu Oct 08, 2009 8:09 pm ]
Post subject:  what fan pulley do I use?
I am undertaking a engine swap in a 68 deluxe, she's getting a 1310.
What pulley should I use, I have the choice of either single "v" & double "v" versions, because of the thicknes of the face of the double "v" it appears that the pulley sits further away from the water pump & the fan blade closer to the radiator buy about 5mm or so, using the single "v" the fan blades are very close (3mm) to the bottom pulley.
the single "v" was from the old 998 & the double "v" from the new motor, I assumed the double "v" was from a late model running A/C etc.
What pulley should I use?
currently running a 16 blade metal fan
Author:  drmini in aust [ Thu Oct 08, 2009 9:06 pm ]
The double V pulley was from the air pump equipped 998s etc of 1977-78.
I prefer the tin single V one...
Author:  junior [ Thu Oct 08, 2009 9:17 pm ]
if I use the single v, do I need to use a spacer, ie will there be any misalignment between the alternator & bottom end pully?
Author:  drmini in aust [ Thu Oct 08, 2009 9:41 pm ]
You should NOT need a spacer behind the fan pulley.
Mine has one in there, but only because I use a belt drive cam kit (not a chain) and this pushes the bottom pulley out slightly.
Put a straightedge there to check alignment if in doubt.
Author:  mini maxx [ Thu Oct 08, 2009 9:59 pm ]
Use the twin pulley and run dual alts :lol: That would be AWESOME :lol: :lol:
Author:  GT mowog [ Fri Oct 09, 2009 6:54 am ]
From my experience the Water Pumps are not alway assembled accurately and the drive flange face is not always in the correct location, so some variation can be attributed to that. I'd suggest a standard single V pulley and add the thin (~4 mm) as required. Just check clearance from the engine pulley / harmonic Balancer and of course the radiator.
Don't be tempted to bend the fan blades.
Author:  junior [ Fri Oct 09, 2009 9:50 pm ]
got it sorted, using the single v.
As GT Mowog suggested the pump drive flanged was a little too close to the pump body, pulled it out a few mm and all is good.
cheers & thanks for the advice
Author:  mini maxx [ Fri Oct 09, 2009 11:03 pm ]
On ya junior :D
