It is currently Sat Jul 26, 2025 9:23 pm
 Post subject: Gapping piston rings
PostPosted: Fri Oct 09, 2009 12:09 pm
Currently doing my first rebuild and would like to know what the gaps should be on the rings. It is a 998cc +0.020", couldn't find values in the haynes manual.
Also what are the consequences of having too large or too small of a gap? Excessive wear?
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Fri Oct 09, 2009 12:56 pm
Tomboss Breweros
I don't have a manual handy so i can't tell you the gap, but,
Too small a gap and with heat the gap can totally close and lock the ring in the bore, potentially causing catastrophic bore and piston damage.
Too big and a little compression will leak by, nothing major.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Oct 09, 2009 1:01 pm
Mods rock!
For a standard street motor 0.007" to 0.012". Try to aim for the lower figure (smaller gap). For 'hotter' and more high performance use, 0.010" to 0.015" depending upon specific use.
If the gap is too small there is a risk of sizure.
PostPosted: Fri Oct 09, 2009 1:35 pm
It will be running a RE13T cam with a SC12, so I guess I should be aiming for 0.010"-0.015".
Users browsing this forum: 78Clubbie and 90 guests
