It is currently Wed Jul 23, 2025 6:41 pm
PostPosted: Fri Oct 09, 2009 7:25 am
Hi all,
I'm rebuilding my engine and my book im using doesnt really have a good example of the clutch set-up and i was wondering if anyone had an exploded diagram of the clutch set-up on the 1100S 1275 so i can put it back together!
Thankyou
Hi-Ho Silver LS1275
PostPosted: Fri Oct 09, 2009 10:40 am
Hi
There really isn't any real difference between an 1100S clutch and a mini clutch - send me your email address by PM and i will email you a set of exploded diagrams in pdf format.
Disregard the segement on verto clutches - thats not what you have.
As for adjusting it - the same applies - its the same as any other mini - read the manual several times - then get a friend or partner to read it as well and then have that person explain their interpretation of it to you.
Do make sure you read the section on aligning it with the "A" etc - that bit is very important.
Mike
PostPosted: Fri Oct 09, 2009 1:28 pm
Mike
:roll: if your pressure plate actually has the" A" stamped on it, stumped me for 20 mins
Users browsing this forum: Steam and 113 guests
