4myego wrote:
Must agree with Mick, Rubber grease works wonders combined with the plastic kitchen spatular.
Found he easiest way, is the put the rubber into the flange first. (make sure you have the Aussie seal (smaller)). Soft hammer all around the make sure it is in. No grease at this stage
Then apply the rubber grease to the glass gap. Only once the seal is fully in the flange.
Drop the lower edge of the glass into the seal (on the bottom of the opening flange).
Push to one side, then work around with the platsic splatular. Very quick, before wife comes looking for kitchen tools!.
Make sure you have a helper inside the car forcing the glass into the seal.
Clean spatular and put back in the draw quick sticks.
Wait for next time. You can always blame the cat, if she asks what happened to the spatular??
Smart like frog!!
OK, thanks. From your post above, it sounds like you're installing the glass from the inside of the car, yes? It would make sense, with the rubber being thinner there?
I will look for the right hi-tech mini windscreen spatula installation tool...my wife's version of "cooking" is opening a can of Spaghetti-O's for the kids, so I don't think I'll meet too much resistance there...
Also, someone mentioned having the correct Aussie seal. Minimania here doesn't sell anything but the longer ones, but they say to cut them to fit. I have done this and used some contact cement to glue it back together, but it still wants to give way during installation. Any great product for gluing the rubber ends together that is strong enough to survive installation?
Thanks as always,
bmc
