i had a 65 deluxe with hydro, lots of other minis, and now have a 1988 Rover Austin 1000.
My Deluxe with hydro had 12x5 wheels and stuck to the road like bear poo to its hairy back side. I am with Doc. There is just something about hydro that normal suspension just doesnt give. I did have competition bump stops all round and that car just jammed into a corner and pulled out as if there was a straight road running through.
My Rover has the hi los and the modern day cone/spring/shock combination as well as (now) 13x7 wheels. The feel is bouncier, bumps feel a little mroe shuddering and cornering makes you think twice about the exact speed/braking/steering combination your using, but to be honest, i havent seen that much difference between the two in the speed vs corner ability.
In driving heaps of minis there are SO many things taht change the way you drive. Brakes, the seat cushioning and side bracing, the seatbelts, the steering wheel, the wheels, the tyres, the road condition, if its auto or manual, the roadworthiness of the car, the way the car has been treated, ....... hold me back from going on.
If you ask me, set the car up to how you like it and drive it how you drive. Its going to be impossible if you ask me to find a car that will act how you want it to act.
