why is everything difficult
https://www.ausmini.com/forums/viewtopic.php?f=2&t=57810
Author:  Goldbrocade_62 [ Sun Oct 11, 2009 8:52 am ]
Post subject:  why is everything difficult
Replaced mates cv joint in his van splines to big in diameter had to linish down then the thread was wrong 18x1.5 instead of unf, lucky I have a lathe to turn and rethread nut or car would still be at my place why can't they supply nut if they change things
Author:  drmini in aust [ Sun Oct 11, 2009 8:55 am ]
I agree.
I had one recently on mini mad's car where the thread was metric, nut was supplied but 5mm too thick for the pin to go through.
I torqued it up, marked which slot, then milled that one 5mm deeper.
Author:  Drexxle [ Sun Oct 11, 2009 1:11 pm ]
i bought one cv from minisport, and another from minitopia, both new, both looked the same.
but they both have a different thread and nut. one is 1 1/4, the other is 1 1/8.
Author:  mini_mad_matt [ Mon Oct 12, 2009 7:16 pm ]
You know what else annoys me, rear wheel bearing kits, the split pins are too big!
Author:  sgc [ Mon Oct 12, 2009 9:13 pm ]
Ah, so it's not just my bad luck then :lol:
Author:  Mini Mad [ Mon Oct 12, 2009 9:27 pm ]
Yeap in the last year and a half i've had 4 different types of CV's with different thread/nut combos, nuts that are wrong, and the same deal with the splines too big as kev said...bloody stupid.
Author:  Phat Kat [ Mon Oct 12, 2009 9:49 pm ]
Your ears must have been burning!!! I was just bitching about that earlier :lol: :lol:
Author:  TheMiniMan [ Tue Oct 13, 2009 12:01 am ]
"""Nothing""" is difficult,,, & the imposible just takes a little longer :-)
Author:  mini_mad_matt [ Tue Oct 13, 2009 6:25 pm ]
It just really annoys me when manufacturers make a product but they don't take a moment to think wether the split pin is right, or for example, a cv boot kit for some modern car i did a while back, it came with plastic cable ties, which weren't even big enough to go around the cv joint.... (not to mention they weren't metal ties, so i used welding wire). EPIC FAIL i say
