It is currently Mon Aug 18, 2025 11:10 am
 Post subject: MIG question
PostPosted: Sun Oct 11, 2009 4:59 pm
I'm working on the Mini so it's Mini related :roll:
Tutorials and How To's on MIG welding say or show the contact tip protruding about 1/8" past the end of the gas shroud. My MIGs original setup and the replacement bits I got the other day are the opposite with the tip inside the shroud about 1/8" - what is correct? (or better)
David L
 Post subject: Re: MIG question
PostPosted: Sun Oct 11, 2009 5:17 pm
G'day Wombat, how've you been?
The set up that you have is better suited to sheet metal 3.3mm and thicker, for lighter stuff like mini bodies you do want your contact tip to extend past the shroud by 3.2 mm (think thats the common size).
But its no secret that I'm not big on MIG personally so I don't use it that much. The Doc used to work for Rheem as a fitter so he has HUGE amounts of MIG experience, hopefuly he will stop by and offer his 2 cents :D Cos he probably knows a few MIG tricks that I don't.
PostPosted: Sun Oct 11, 2009 6:24 pm
My MIG has the tip about level with the shroud, which works okay. However a lot of people recommend trimming the shroud so you can see the arc better. A longer shroud may help with shielding gas, but if yours is the normal type, you can pull the shroud forward up to 1/2 inch if you're having problems with the shielding gas getting blown away.
PostPosted: Sun Oct 11, 2009 7:13 pm
Mine is screw on - fix distance - guess I'll have to attack it with a hacksaw
David L
PostPosted: Sun Oct 11, 2009 10:18 pm
With small wires you use less wire stickout from the tip than big wires, the general rule here (ref Linde Gas's MIG data sheets) is 13x the wire diameter for good starting and running. Applies to all wire sizes.
I have the contact tip about 3 or 4mm outside the shroud. Makes it easier to see the arc, puts much less spatter in the nozzle too.
Users browsing this forum: No registered users and 124 guests
