Clutch issues https://www.ausmini.com/forums/viewtopic.php?f=2&t=57819 |
Author: | 9/61 [ Sun Oct 11, 2009 4:36 pm ] |
Post subject: | Clutch issues |
After a day of driving all over he country side I'm almost home and my clutch pedal goes hard half way down... confused? I can't engage gears! Can anyone suggest what could be the problem? I have a 1 year old slave cylinder, the bore of the master looks fine as do the rubbers. The hose to the slave is old but I can see no leaks, but when I push the slave piston in by have I get fine air bubbles in the master. Also now when I try the system I have to pump the pedal to get pressure and it does not last. Another thing I see to have a lot of free play in the actuator arm and when I spin the bearing plunger it feels a bit crunchy but I get no bad bearing noise. Any constructive feed back would be appreciated. |
Author: | TheMiniMan [ Sun Oct 11, 2009 4:56 pm ] |
Possibly a broken clutch arm (at the ball on the bottom, inside the throw out carrier) Maybe,,, & if so, then "Maybe" the slave piston is now traveling all the way to the end & buttoning on the circlip Maybe??? |
Author: | 9/61 [ Sun Oct 11, 2009 5:32 pm ] |
Thanks miniman but the arm is fine. |
Author: | mini maxx [ Sun Oct 11, 2009 5:37 pm ] |
Those 2 clutch adjustment nuts maybe......wound them selvs on a bit too far after a long vibrating drive maybe. Im no expert and i dont want to start a civil war but thats my opinion any hoo |
