It is currently Tue Aug 19, 2025 12:46 am
PostPosted: Sun Oct 11, 2009 6:31 pm
I am still trying to make stuff fit from one car to the other. The clubman had an 1100 radiator and buggered if I can get it to fit in my round nose, Only thing I can think of is to ditch the shroud, but doesnt that defeat the purpose of having a better radiator?
Any info/ideas welcome !
PS thinking of just ditching it and getting alloy rads instead, but annoyed as I have a 1100 radiator that works just fine. (given it was on a supercharged 1330 engine it must be okay?)
cheers miki.
PostPosted: Sun Oct 11, 2009 8:32 pm
I used just the top half of the shroud on my roundie with a morrie 1100
radiator, I also panel beated the top tank a little bit, to clear the bonnet.
I had no cooling problems with my 1330 ( I also ran a mini heater core as a extra radiator behind the grill ).
PostPosted: Sun Oct 11, 2009 9:03 pm
The shroud will fit with some fiddling, but you will need to bash the top tank flat a bit and modify the safety catch, or the bonnet will not close.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Oct 11, 2009 9:18 pm
Righto.. so beat the crapola outa the top tank *check*
temp remove safety catch *check*
remove top half of the shroud *check*
then...
buy an alloy radiator to make it look nicer and fit!
Thanks for the help, I wanted to make sure beating the crap outa it was the right thing to do.
cheers miki.
PostPosted: Sun Oct 11, 2009 9:21 pm
You got it. Unfortunately I don't think there is a way of making it neat. :(
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: Bing [Bot] and 301 guests
