It is currently Wed Aug 13, 2025 7:52 am
 Post subject: Pulling Right
PostPosted: Sun Oct 11, 2009 1:09 pm
ive done brakes quite a few times with no hassles. I smashed a brake line on the oodnadatta and had to quick repair it, and managed to get double pump brakes.
now im in Alice, ive had a new line made up and put that on, and checked all pads for wear, adjusted all adjusters. the same process ive always done before.
except this time, when i hit the brakes hard, the car will severely stear to the right.
I kept think readjust the adjusters (in the forward direction on the front sets) and i cant seem to get rid of the severe pull to the right on hard braking.
Any ideas.
PostPosted: Sun Oct 11, 2009 1:22 pm
did you adjust just one side only
PostPosted: Sun Oct 11, 2009 1:29 pm
no, i took all drums apart, cleaned, checked all pads, adjusts all drums, bled all lines and added new fluids, checked for leaks etc, (smashed a line and bent a nipple on track).
i went through two bottles of fluids to get all air out. Pads are worn, but still have a good 4-5mm on them.
PostPosted: Sun Oct 11, 2009 1:53 pm
Mods rock!
Check your radius and lower arm rubbers and your tyre presures
PostPosted: Sun Oct 11, 2009 2:08 pm
tyres are all good, i have a good 12v tyre pump, check all the tyres.
ill check the arms for wear. Thanks
PostPosted: Sun Oct 11, 2009 2:10 pm
what brake line did you smash and how did you smash it ? Is it possible that you bent the brake backing plate or somehow pushed a wheel cylinder out of position slightly ? Are you sure when you bled the brakes both wheel cylinders were working properly on both sides ? Look for something obvious in either side front brake , something causing one to grab OR one to not work .
PostPosted: Sun Oct 11, 2009 2:14 pm
was the short line from the hub to hose on the rear righthub. the nipple that was bent the one on the front right.
i took the cylinder out to clean everything up and make sure it was put back together properly. the cylinder didnt look damaged on the rear, and i put some thread lock tape and a new nipple on the front cylinder.
i guess, i just have to go through the car, front to back again.
PostPosted: Sun Oct 11, 2009 2:20 pm
ok , i was thinking it must have been a front brake hose you broke off . I'd be looking at the front brakes though , they would be more likely to cause the car to pull either way , a rear will normally just lock or slowly pull one way of the other . As a thought check if the thread tape is blocking the fluid .
PostPosted: Sun Oct 11, 2009 3:34 pm
Steering arm or something in your steering department?
Could be a whole range of possibilities
PostPosted: Sun Oct 11, 2009 6:09 pm
One of the drums elliptical and needs to machined ?
Have to do both so there the same.
PostPosted: Sun Oct 11, 2009 7:34 pm
This space for rent
Are both your caster bars straight?
[edit] and tight? What condition are the caster bar bushes in? If you've destroyed the outer one then the car will pull to that side under brakes.
Users browsing this forum: No registered users and 294 guests
