Nuts!!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=57836 |
Author: | Blunder [ Sun Oct 11, 2009 7:01 pm ] |
Post subject: | Nuts!!! |
Can anyone tell me the length and diameter of mamba/revolution wheel nuts?! Think these maybe pretty close to what i need. Jellybean nuts are the right diameter @ 12mm but way too short i need about 27mm is give or take a little! Also on a side note what thread is the mini wheel stud?! All helps with sourcing myself some new nuts for my speedy rims! Thanks |
Author: | mini maxx [ Sun Oct 11, 2009 7:32 pm ] |
Author: | Blunder [ Sun Oct 11, 2009 7:40 pm ] |
Maxx thats not very constructive! |
Author: | mini maxx [ Sun Oct 11, 2009 7:49 pm ] |
Author: | Blunder [ Sun Oct 11, 2009 7:50 pm ] |
doesn't really do anything contructive though or help this thread Maxx... unless you actually have any answers!? |
Author: | 74snail [ Sun Oct 11, 2009 8:15 pm ] |
3/8 thread Mamba Wheel Nuts Length top to bottom : 48mm Length of straight : 33mm Diameter at narrow section : 14mm Washer Diameter : 24mm Washer depth 4mm Nut / Spanner size 19mm Is that better ? . |
Author: | Blunder [ Sun Oct 11, 2009 8:17 pm ] |
Dam... too wide and long! need 12mm diameter and 28mm ish length! But hey good start to get a lathe on them!!! |
Author: | frednutz&co [ Sun Oct 11, 2009 8:18 pm ] |
max ![]() ![]() ![]() ![]() |
Author: | mini maxx [ Sun Oct 11, 2009 8:21 pm ] |
Freddo, you missed the pre edited version, i suggested he use those wooden blocks hes so fond of ![]() |
Author: | 92 [ Sun Oct 11, 2009 8:27 pm ] |
Post subject: | Re: Nuts!!! |
gareth-in-adelaide wrote: Can anyone tell me the length and diameter of mamba/revolution wheel nuts?! Think these maybe pretty close to what i need.
Jellybean nuts are the right diameter @ 12mm but way too short i need about 27mm is give or take a little! Also on a side note what thread is the mini wheel stud?! All helps with sourcing myself some new nuts for my speedy rims! Thanks The nuts I have for my speedy hotwires are 17.2mm diameter probably clearance for 11/16" and are 19mm long on the stepped part. They also need a washer this should be captive in the wheel but sometimes fall out. The washer is 4mm thick with said 11/16" hole and the outside diameter is tappered from 23.2mm to 21.9mm. Thread is 3/8UNF Overall length is 41mm Hex head 13/16 hex x 22mm long Hope this helps |
Author: | Boyracer [ Sun Oct 11, 2009 10:32 pm ] |
As far as I know, there are at least two types of Revolution wheel nuts. Here's a pic of the earlier ones. I had to get them made up when the panel shop threaded one of mine. I had four made and used one. [IMG]http://img.photobucket.com/albums/f357/BoyracerAU/Mini/NewNuts.jpg[/IMG] The later type are as offered for sale by all the Mini shops. They're no longer tapered. [Why isn't my pic showing?] ![]() |
