It is currently Sun Aug 17, 2025 9:27 pm
 Post subject: Ignition Switch
PostPosted: Mon Oct 12, 2009 7:31 pm
Never had my mini running and just put back in the ignition switch. On the key that was supplied with the car it only has:
OFF - ON
I would have thought it should have:
OFF - ON - STARTER
No floor start as it is a 1965 Deluxe. What should it be?
Thinking might need a new barrell and key?
Regards
Dave K.
PostPosted: Mon Oct 12, 2009 7:50 pm
Deluxe one had long barrel, was off-on-start.
850 was short barrel, off-on.
Karcraft should have new Deluxe ones.
Mine is a 1970 Matic, long barrel, it has accessories-off-on-start. Not sure if original?
 Post subject: Ign sw.
PostPosted: Mon Oct 12, 2009 7:52 pm
I think on a 65 Model it should have key start. Check if it has hole drilled out in the hump on the driver's side floor. And make sure if it has been modified that it does not have any silly and dangerous starter cable joined under there.
"Let us remove your "SHORTS"
PostPosted: Mon Oct 12, 2009 7:56 pm
yes - definately a key start. Powered up the loom and the parking lights come on with the lighting switch but main headlights don't light up.
Will take the barrell out - how long is long Kev?
Dave K.
PostPosted: Mon Oct 12, 2009 7:59 pm
The short barrel 850 one the nut sits against the panel.
The long barrel ones have a chromed spacer about 1/2" long behind the nut, so the keys don't rub on the panel.
PostPosted: Mon Oct 12, 2009 8:04 pm
Thanks Kev - just went and had a look and I have the spacer there. Have to go to Karcraft to get some new bumpers so will try to get a new lock barrell and key.
Does the barrell just come out when the nut is taken off?
Dave K.
PostPosted: Mon Oct 12, 2009 8:49 pm
There is a little pin you press in or something to get the barrel out.
I did it last year and can't remember how.
If it was 10 years back, I'd remember it!! :P
Users browsing this forum: Bing [Bot] and 368 guests
