Were does it go to https://www.ausmini.com/forums/viewtopic.php?f=2&t=57888 |
Author: | i got a mini [ Mon Oct 12, 2009 9:06 pm ] |
Post subject: | Were does it go to |
Ok well I have resently put a new motor in and I went to start it with the key and it didn't work the ignition came on so I had to use the push button solinoid on the car to start now I have a wire comming off the back of the ignition when u go to crank the motor over it gets power were does it join up to on the solinoid ??? Which lug I have looked at a manual can't figure it out |
Author: | TheMiniMan [ Tue Oct 13, 2009 12:03 am ] |
The wire is White, with a thin red trace the terminal for the start is in between the 2 big terminals but just down the solinoid a tad Edit--> maybe you have mixed upo the "Oil Warning wire" with the start wire... oil warning wire is white with a thin brown trace |
Author: | i got a mini [ Tue Oct 13, 2009 6:11 am ] |
Ok the thing with my car is that none of the wire colours are right thanks to the bloke who had it before me so it is hard to tell I have put this wire there and nuffin happens could my solinoid be shot |
Author: | Morris 1100 [ Tue Oct 13, 2009 4:51 pm ] |
Run a jump wire from the battery side of the solenoid to the little terminal on the solenoid and see if the solenoid works. |
Author: | i got a mini [ Tue Oct 13, 2009 10:24 pm ] |
And if nothing happpens wat does that mean |
Author: | TheMiniMan [ Wed Oct 14, 2009 11:23 am ] |
i got a mini wrote: And if nothing happpens wat does that mean
that means the solinoid isn`t working, or your battery terminal (on the solinoid) isn`t connected to the battery, or your battery is flat if there`s a slight """Clicking""" noise then it could still mean that the solinoid is orking & the starter is buggered,,, But it could also mean that the solinoid isn`t working (properly) it can be throwing in but not contacting properly/cleanly,,, so you`d then have to check to see if there is any power at the starter terminal while you have power at that little trigger terminal on the solinoidto determine whether it`s the starter that`s buggered or the solinoid that`s buggered |
Author: | i got a mini [ Thu Oct 15, 2009 2:07 pm ] |
It is one of those push button starters were u caN start the car from the engine bay I did the wire thing and nuffin happened but when I push the button starter motor comes on so solinoid I recon |
