It is currently Mon Jul 28, 2025 12:43 pm
PostPosted: Fri Oct 23, 2009 7:42 pm
Tell me about your set up , airfilter , needle , etc etc
PostPosted: Fri Oct 23, 2009 8:37 pm
My 1412 stroker with RE13 cam and Corolla rockers made 113.6HP and 113ft/lb torque on Graham Russell's engine dyno with an HS6, the needle was an OA6.
No airfilter was used for the run, but when installed I intend to use a Ramflo filter and Unifilter LNX300 foam. That should not change the mixture much if at all.
<edit> fixed typo. :wink:
Last edited by drmini in aust on Fri Oct 23, 2009 9:46 pm, edited 1 time in total.
PostPosted: Fri Oct 23, 2009 8:40 pm
If I use a single HS6 on my 1275 auto , I will probably use an RF needle ( I must admit I don't know if its fixed or floating ) and a K&N filter. As for the manifold, heated obviously , I have been trawling Ebay Italy for an Innocenti manifold , I will find one .
PostPosted: Fri Oct 23, 2009 8:42 pm
Supercharged
i use a single HS6 on my supercharged engine, it uses a custom profile needle and has a k&n filter on a custom billet ramtube. it has over 100 bananas at the wheels
PostPosted: Fri Oct 23, 2009 9:42 pm
My 1412 stroker with RE13 cam and Corolla rockers made 113.6HP and 113ft/lb torque on Graham Russell's engine dyno with an HS6, the needle was an A06.
Doc,,, would that be an "0A6" ???
PostPosted: Fri Oct 23, 2009 9:45 pm
Um yeah it would, me dyslexic am... :lol: :oops:
will correct above. :wink:
PostPosted: Fri Oct 23, 2009 10:04 pm
Tomboss Breweros
HS is float at the side right?
Mine is on a warm 20 thou over 1100, i modified the carb as per Mr vizards specs, match ported the manifold to the carb and head, and my own bell mouth to fit in the ram flo filter.
And yes i wear gloves when working on cars, even the newest ones are filthy.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Oct 24, 2009 6:55 am
I have fitted a couple of HS6's with water heated manifolds to 1275 + engines.....they work quite well......normally fit the offset ramflo airfilter.
Needle size depends on what the engine needs.
PostPosted: Sat Oct 24, 2009 8:05 am
I have a HS6 on the stock 1299cc Moke. That one is on a 1.5 inch manifold that has been modified to suit. The needle is a OA6, Ramflo offset filter.
I also have one on Slidey, a 1360, 1.5 rollers, big cam but a stock head at the moment. The HS6 is sitting on a Graham Russell manifold and uses a Ramflo offset again. It has a OA6 needle but we feel that it's a bit lean. When I get this engine set up properly I'll get some dyno time booked.
They say that the OA6 is a good starting point. :)
PostPosted: Sat Oct 24, 2009 8:11 am
You sooky big girls blouse :roll: Drink a cup of concrete and harden the f*ck up :lol: :lol: Grime is good for ya :wink:
PostPosted: Sat Oct 24, 2009 6:09 pm
:P Not everyone works in "pre-delivery" of a new car dealership Mini Maxx :!: :lol: :lol: :lol:
PostPosted: Sat Oct 24, 2009 6:37 pm
You don't really need to buy a stubstack with an HS6. There is enough meat in the inlet flange to just put it in a lathe and machine a 4mm radius in there instead. GR did mine.
Anything over 3mm works OK. :wink:
PostPosted: Sat Oct 24, 2009 7:42 pm
WTF :shock: do i :?:
PostPosted: Sun Oct 25, 2009 9:49 am
Be careful about what the HS6 comes off. Particularly the tilt of the float chamber. If its off a jag or the like it will need modifying in the connection float chamber area.
Minis have their carbies of a 13 degree tilt. Jags dont and if its not corrected fuel will just run out the needle jet.
Mike
PostPosted: Sun Oct 25, 2009 9:58 am
Nice one Mike , I assume that the stamp numbers on a Jag HS6 will be different to a Mini one ?
Users browsing this forum: fuzzy-hair-man and 89 guests
