It is currently Tue Jul 22, 2025 3:29 am
 Post subject: Crusty RHS tank
PostPosted: Fri Apr 01, 2005 8:18 pm
I've managed to pick up a right side fuel tank very cheap but its rusty. There was 2 small holes that I've repaired so it doesn't leak now. But, the inside of the tank is very crusty looking.
To clean it I put in about 200 small lead sinkers and shook the tank for about 10 minutes, then flushed out all the crud with a garden hose and water.
Is there something I can put in the tank to help preserve it while its in use? Something that will sit in the bottom or coat the inside of it to stop it rusting any further and won't be affected by constant soak with fuel. And most importantly something that won't end up in the engine.
Thanks for any advice/suggestions.
PostPosted: Fri Apr 01, 2005 8:20 pm
Go to a motorbike shop, there's a product made specially for this. Coats the whole insides with a resin-like material. It will never leak again. :P
PostPosted: Fri Apr 01, 2005 8:21 pm
When full of fuel it wont rust. They wont rust unless moisture gets in there.
PostPosted: Fri Apr 01, 2005 8:24 pm
Um... heating during the day then overnight cooling will pull moisture laden air in there, the water condenses and lays in the bottom of the tank `coz it's heavier. How do I know this? I own a BOAT... :lol:
PostPosted: Fri Apr 01, 2005 8:30 pm
This sounds good. Thanks for the tip.
PostPosted: Fri Apr 01, 2005 9:22 pm
this one comes highly recommended....
http://www.ppc.au.com/category33_1.htm
and I have bought from these guys....super service!!!!
PostPosted: Fri Apr 01, 2005 9:29 pm
Awww brilliant!!! Thanks guys.
Enjoy the vid I just posted to the video section.
PostPosted: Fri Apr 01, 2005 9:36 pm
im just picturing you shaking a fuel tank with 200 lead sinkers in it for 10 minutes... :lol:
PostPosted: Fri Apr 01, 2005 9:38 pm
Sooooowww whhaaatss sooooo funnnnnyy abbbooout thaatttt?
PostPosted: Fri Apr 01, 2005 9:48 pm
who needs to go to the gym.... :lol:
PostPosted: Fri Apr 01, 2005 9:58 pm
Gtimini's neighbours.....
"What's the freak up to now"
"Oh, he's dancing around the back yard wearing a hula skirt shaking a giant maracca"
Tee hee....
PostPosted: Fri Apr 01, 2005 10:08 pm
You've been peeking again havn't you!!! :lol:
