It is currently Thu Aug 14, 2025 9:52 pm
PostPosted: Tue Oct 13, 2009 12:48 pm
Milatsmadmini
Am considering going down the path of S/C small bore (998 + 100thou O/B, lightened bottom end, X pin diff etc)
S/C will be a sc12.... carb will be of the HIF variety... What needs to be done to the carb to suit this type of application?
PostPosted: Tue Oct 13, 2009 1:02 pm
Nothing.
They work exactly as intended in a suck through application.
PostPosted: Tue Oct 13, 2009 1:09 pm
you may find that a stronger spring is needed & obviously the correct mixture needle to suit
PostPosted: Tue Oct 13, 2009 1:15 pm
Milatsmadmini
der Matt *smacks forhead* :oops:
thanks AWD and matty...
Ok whilst on the subject, what about blow thru, what is needed that way?
PostPosted: Tue Oct 13, 2009 1:24 pm
A HIF turbo carb, or convert yours to have the necessary shaft seals, etc.
Users browsing this forum: No registered users and 292 guests
