Modifying carb for Suck Thru s/c set up? (ie. carb b4 S/C) https://www.ausmini.com/forums/viewtopic.php?f=2&t=57901 |
Author: | mattsmadmini [ Tue Oct 13, 2009 12:48 pm ] |
Post subject: | Modifying carb for Suck Thru s/c set up? (ie. carb b4 S/C) |
Am considering going down the path of S/C small bore (998 + 100thou O/B, lightened bottom end, X pin diff etc) S/C will be a sc12.... carb will be of the HIF variety... What needs to be done to the carb to suit this type of application? |
Author: | awdmoke [ Tue Oct 13, 2009 1:02 pm ] |
Nothing. They work exactly as intended in a suck through application. |
Author: | TheMiniMan [ Tue Oct 13, 2009 1:09 pm ] |
you may find that a stronger spring is needed & obviously the correct mixture needle to suit |
Author: | mattsmadmini [ Tue Oct 13, 2009 1:15 pm ] |
der Matt *smacks forhead* ![]() thanks AWD and matty... Ok whilst on the subject, what about blow thru, what is needed that way? |
Author: | awdmoke [ Tue Oct 13, 2009 1:24 pm ] |
A HIF turbo carb, or convert yours to have the necessary shaft seals, etc. |
