Fuel sender?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=5800
Author:  64morris [ Thu Mar 24, 2005 10:19 pm ]
Post subject:  Fuel sender?
ok a while ago i bought nice new shiny gauges for the mini. went back and got the senders for them later. all was good but i thought that the fuel sender looked a bit odd to go in a mini tank but the guy told me it was for a side mounting tank so i take it anyway...
about a week ago i got around to fitting it only to find it is very very wrong the arm comes out of the resistor unit thing from totally the wrong way so i take it back. i explain whats wrong and what does he tell me to do "bend it" so i say "no this would make it very inaccurate". so at the moment i am trying to get my money back but am waiting to speak to the owner. the pleb i dealt with reckons they cant take it back but thats another story.. so has anyone got a gauge the same as this and if so can you tell me where to get the proper sender or do i in fact have to "bend" or "modify" the sender they gave me?
thanks alot
Author:  Marvin [ Thu Mar 24, 2005 10:27 pm ]
mine read wrong when I bought the car so I bent it and it's now close enough.
Author:  gafmo [ Thu Mar 24, 2005 10:32 pm ]
Have you got a Pictures of this Wrong Sender, May help
Author:  64morris [ Thu Mar 24, 2005 11:01 pm ]
ok here are some pics of the sender. also some crazy diagrams to try and explain what i mean. :| karkraft have a fuel sender unit in their catalogue but they dont know if it will work with this gauge.
Author:  gafmo [ Thu Mar 24, 2005 11:10 pm ]
It does look like the same as Morris..
I think it is packed straight for shipping purposes :wink: and the crude Digram re-enforces it...I THINK you would bend it before the coneections I can have a look once the fule is down :?
Author:  64morris [ Fri Mar 25, 2005 10:51 am ]
thatd be great thanks gafmo do you reckon you need to bend it at the resistor connections?
Author:  miniron [ Fri Mar 25, 2005 10:53 am ]
:shock:
Consumer protection laws mean it has to be "Fit for purpose". Unless it's for a very early mini with the screw mounting it probably won't seal any way even if you do bend it. Later Mini tank senders use a rubber seal and a tapered locking ring. Not a good move to bend it as then they can say you damaged it and you won't be able to take it back.
RonR
