It is currently Sun Aug 03, 2025 10:03 pm
 Post subject: Speedo cable position
PostPosted: Thu Oct 22, 2009 9:02 pm
I have a 63 Morris with a 3 gauge clubman dash in it and the speedo cable is rubbing on my K&N filter because I have the speedo coming through the center hole in the fire wall.
So, in a Clubman where should the speedo cable come through the fire wall?
PostPosted: Thu Oct 22, 2009 9:28 pm
Tomboss Breweros
On my clubbies it comes through the firewall near the master cyl's then virtually runs along the firewall behind the carb.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Oct 22, 2009 11:26 pm
Same as Veras speedo cable
PostPosted: Fri Oct 23, 2009 6:37 am
Mods rock!
This may also help;-
http://www.ausmini.com/forums/viewtopic.php?t=58134
