GT mowog wrote:
michaelb wrote:
I did both my swing arm bushes a few weeks ago with a short ream and was very careful and took my time. The 1st bush was ever so slightly at an angle which I managed to straighten out to fit the shaft in and run straight with the bearing, the sedond one was almost spot on. Just need to try and keep the ream square and straight.
I see nothing at all wrong with this. They are not a high speed bearing - far from it, if it does bind a
little, so what? It won't take long to sort itself.
Interesting the 13" wheel mokes run bearings both ends,
but IMO Mini's and Moke's should run bushes both ends.
In 1959, the UK Minis DID have bronze bushes both ends. But, the load on the inner one (where the suspension strut pushes) was too great, it resulted in the arms seizing on the shafts (maybe more greasing would have helped).
So, very soon they put a needle bearing in place of the inner bush, to take the load.
With the Oz bigwheel Moke, they replaced the outer bush with another needle bearing, again to take the extra load.
IMO, needle bearings are better, IF the shaft is at least 61C Rockwell hardness. If not, the rollers flake the soft shaft surface up.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
