It is currently Mon Jul 21, 2025 5:58 pm
 Post subject: Sagging doors
PostPosted: Fri Mar 25, 2005 11:54 am
OK the bottoms of Mo's doors are sticking out now from the rest of the car. For those "simple" minded like me, what is the best way to pull this back in and improve the alignment..?? :? I have been given suggestions which vary from playing with the hinges to removing the door and flexing it to playing with the striker plate.
PostPosted: Fri Mar 25, 2005 11:56 am
What are ya hinges like?
If ya open the door and lift the rear of the door up, does it lift up heaps?
PostPosted: Fri Mar 25, 2005 12:05 pm
will have to check but I think that there is about 3mm - 5mm lift.
PostPosted: Fri Mar 25, 2005 12:07 pm
A little bit at the hinge will be magnified at the other end of the door.
PostPosted: Fri Mar 25, 2005 12:11 pm
Ok ... so to fix this is it the hinge pin or hinge screws that need to be replaced..? The hinges themselves seem pretty good (but I am sure someone with more knowledge would tell me otherwise... :wink: )
PostPosted: Fri Mar 25, 2005 12:13 pm
Not sure if hinges are causing most of the problem, it's really something i'd have to see.
PostPosted: Fri Mar 25, 2005 1:26 pm
It's most likely your hinges, they get saggy with use, the drivers side more so.
You can get new pins to rebush your existing hinges...
Users browsing this forum: Bing [Bot] and 66 guests
