I've PM'd a few folk already, but I thought I'd start a thread too.
A good friend is restoring a 67 S and is about to put on the paint, we had a discussion about whether his front panel was correct?
The earlier type had wide spaced number plate brackets and an extra fill in piece at either end of the grill opening, we'll call these the wide spaced front panel.
Later panels were a one piece pressing with narrow spaced numberplate bracket loops, to better suit Aussie rego plates, hence the narrow front panel.
When was the changeover, I have a 66 shell with the wide panel and a 68 with the narrow, can any one get closer to the actual changeover?
Did this coincide with the dimple scuttle for Aussie style left park wipers?
Approx chassis numbers would help pin it down
Cheers...... Graham
