Oil pressure gauge pipe question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=58158
Author:  miki [ Fri Oct 23, 2009 12:21 pm ]
Post subject:  Oil pressure gauge pipe question
Is it okay to run this pipe through the bulkhead with other wires nearby? or does it get hot enough that it might compromise *melt* the electrical wires?
Author:  Tombo [ Fri Oct 23, 2009 1:05 pm ]
Shouldn't get hot at all as oil doesn'f flow continuously, just pushes up a bit when pressure builds then back out as pressure drops.
Just make sure the pipe is insulated from the bulkhead, the last thing you want is an oil shower in the car.
Author:  miki [ Fri Oct 23, 2009 1:57 pm ]
thanks mate.
Author:  BBY755 [ Fri Oct 23, 2009 2:20 pm ]
Yeah,
And don't forget to tighten it properly, or the right dash card will get a little oily!!! :oops:
Author:  DTrain [ Sat Oct 24, 2009 12:10 am ]
and dont unwind the whole copper pipe, leave it wound and it will absorb most of the bumps and knocks
