motor https://www.ausmini.com/forums/viewtopic.php?f=2&t=58164 |
Page 1 of 2 |
Author: | crabby [ Fri Oct 23, 2009 4:44 pm ] |
Post subject: | motor |
Hi, was on the look out for a 1275 motor and gearbox and i just found one. Would like to no the difference between 1275 block and the 1100s as i found this cheap approx ($400) is this a fair price you think and what the best way the trick the motor out ![]() ![]() THANKS ![]() ![]() |
Author: | Phat Kat [ Fri Oct 23, 2009 4:52 pm ] |
Post subject: | Re: motor |
crabby wrote: Hi, was on the look out for a 1275 motor and gearbox and i just found one.
Would like to no the difference between 1275 block and the 1100s as i found this cheap approx ($400) is this a fair price you think and what the best way the trick the motor out ![]() ![]() THANKS ![]() ![]() Howdy crabby,, Lucky for you I'm one of those obsesive compulsive types that keep a record of everything that goes thru ebay ![]() ![]() I think $400 is pretty reasonable. As far as tricking it up goes,, it is a matter of what you want out of it or what you intend on using the motor for (you know, a fast road car, rally, race ect, AC generator) If you can give everyone a clue I'm sure you'll get about 50 hits with people all to happy to give you their opinions ![]() |
Author: | Leighton [ Fri Oct 23, 2009 4:52 pm ] |
to work the motor send it to Graham Russell, he will help you out and probably get you the right ponies and torgue curve. Russell Engineering 113 North Rocks Rd North Rocks 2151 (02) 9630 2195 $400 id say that is a fair price... does it have the radiator, dizzy etc |
Author: | Phat Kat [ Fri Oct 23, 2009 5:19 pm ] |
,,, these guys might be closer http://www.moke.com.au/Joomla/content/view/141/70/ they say that they do do go fast stuff... I don't know what they are like I've never had any work done by them,, but otherwise I'm sure that the Tassie mini club (don't know what you guys call yourselves) could help too... Unless you want to be brave and do your own motor (which is what I think you were getting at),,, it usually costs me about $2000 (including the gearbox) to build a fun street motor... Its a bit cheaper than paying someone else and you will have the satisfaction of being able to say "I did that, thats my motor"... if you've never done one before then it gets a bit hard,, maybe your local mini club might have some members that can help you out for a case of beer? ![]() But if in doubt, ask a question, you might get multiple and different answers but, having multiple ideas is never a bad thing,, it can be,, but it can also give you room to make up your own mind with what makes sense to you. |
Author: | GT mowog [ Fri Oct 23, 2009 5:28 pm ] |
Not a bad buy at $400.00. There are a few very good tuners in Victoria that you can try;- Lindsay Siebler http://www.minis.com.au/ Northern Mini Parts http://www.miniparts.com.au/ Russell Turner [email protected] (03) 9726 3138 |
Author: | BALLISTIC [ Fri Oct 23, 2009 5:33 pm ] |
Or you could try me as I will be in Devonport from the end January 2010 www.minitopia.com.au Or I may even make it to minifest and you can chat to me there |
Author: | Phat Kat [ Fri Oct 23, 2009 5:38 pm ] |
BALLISTIC wrote: Or you could try me as I will be in Devonport from the end January 2010
www.minitopia.com.au Or I may even make it to minifest and you can chat to me there Good on ya ![]() ![]() |
Author: | BALLISTIC [ Fri Oct 23, 2009 6:06 pm ] |
Phat Kat wrote: BALLISTIC wrote: Or you could try me as I will be in Devonport from the end January 2010 www.minitopia.com.au Or I may even make it to minifest and you can chat to me there Good on ya ![]() ![]() ![]() ![]() Change is as good as a holiday, Devo is a nice place. |
Author: | crabby [ Fri Oct 23, 2009 6:20 pm ] |
motor hoping to work mild as i use it to travel to and from work lot of cornnering hopeing to have cam done ect any help will be great |
Author: | miki [ Fri Oct 23, 2009 8:44 pm ] |
Before you send it anywhere.. work out exactly what you want to do with it. And the trick here is to be brutally honest with yourself. About 10 years ago I let me ego get the better of me and had a full race stroked 1425 that I was sure I was going to use on the track/sprints! however all I ever did was fang it around town. Hey nothing wrong with that? WRONG, power came in at tons of revs and it was a bugger to drive. I killed it trying to get up my sisters very steep driveway when one wheel hit dirt and span like hell *diff pin broke* I then proceeded to drive it for 20kms to the garage ![]() Be honest with what you want, what your going to use it for and how much your prepared to pay for it. Also, try not to get competitive with the numbers involved as its easy to get suck into bigger = better. But other than all that GRATS! on your big bore purchase. cheers miki. |
Author: | gafmo [ Fri Oct 23, 2009 8:59 pm ] |
$400 I would say is a good price just depend on what is included. But anyway its a great base ![]() Give him a call on what you want out of your engine and how you want to drive it and he will have the best set up and Cam for you ![]() |
Author: | crabby [ Fri Oct 23, 2009 9:36 pm ] |
it includes eveything exept clutch and pressure plate gearbox included |
Author: | Leighton [ Sat Oct 24, 2009 12:38 am ] |
crabby wrote: it includes eveything exept clutch and pressure plate gearbox included
thats a fair price then, you would most likely replace the clutch anyway and the pressure plate; im sure someone on here will have one lying around |
Author: | BALLISTIC [ Sat Oct 24, 2009 6:13 am ] |
Author: | GR [ Sat Oct 24, 2009 6:45 am ] |
HI All Just a point of intrest all thoes +.060 blocks that need boreing i have 72.5mm pistons which is .o14 tho bigger than +.060 so you have another bore size to save the block then i have 73mm 73.5 and 74mm. Graham Russell |
