What's the trick?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=58168
Author:  Wombat [ Fri Oct 23, 2009 5:56 pm ]
Post subject:  What's the trick?
Having a bugger of a job getting the petrol tank back in. have the drain plug ( or what is left of it) lined up over the hole in the floor but the filler neck is only flush with the hole in a rear quarter panel. Can't get it to move in any further at the top as I think it is foaling on the restraining strap bolt into the back wall.
What's the trick to get them in? Oh and where does the breather tube go?
Author:  Wombat [ Fri Oct 23, 2009 6:24 pm ]
Did it - wasn't using the right swear words. The right words and the HF rubber mallet and a tyre lever did it - now where is the pointy bolt that goes in the lock down strap :?
Author:  GT mowog [ Fri Oct 23, 2009 6:28 pm ]
Has the car ever been in a collision? Maybe the boot floor or body is just a bit outa wack? They are a bit of a squeeze, but they usually go in no problem. Is the bolt on the back of the seat to long? Try a bit of rubber lube on the filler neck.
Author:  Kennomini [ Sat Oct 24, 2009 11:12 am ]
I think I might have a bit tougher job when I put my project back together. The panel beater forgot to drill the hole where the captive nut is for the retaining strap, he left the nut their on the outside just no hole on the inside :roll: I can't drill it out from underneath as the beaver panel is in the way so I think I have to make an educated guess and drill a pilot hole from the inside and hope I get the center of the nut :? then I just have to enlarge the hole with out wrecking the thread. Then I have the fun of actually fitting the tank...
Author:  sports850 [ Sat Oct 24, 2009 11:15 am ]
Can you centre punch the middle of it from underneath Kenno ?
Author:  Kennomini [ Sat Oct 24, 2009 11:22 am ]
No the beaver panel is in the way big time :x
Author:  MI65NI [ Mon Oct 26, 2009 4:20 pm ]
I had this problem also, i can't remember how i done it, a lucky measurement i think. Didn't turn out to bad. had to adjust it a little with a die grinder tho.
